1/24 MPC/Airfix JU 87B Some Color
After nearly two weeks of being sick I am able to show a bit of progress.
I began the process of preparing to get some color on the build. I did this just a bit different than previous builds. I began with a Gloss Black base. I then shot Alclad Polished Aluminium. Mind you this was not done to be a high gloss, mirror finish. Just a base for the color to come.
Once dry the real colors make their appearance. RLM 70 and 71 for the upper and RLM 65 for the lower. I began by taping off the shapes and then shot a lightened version of each of the top colors to get a first color. I then went back through with thinned coats of the colors to darken up the cammo. For the lower I shot several layers of thinned color.
This was done over the cut away sections. I did this to try to minimize any overspray to the interior.
I did have a bit of a mishap. Prior to getting sick I scanned the decal sheet. My son touched up the image to give the best possible color. I then printed off the decals on two sheets, my only two sheets, of decal paper. Once I thought it was dry I sprayed decal bonder. Once I felt up to doing anything again I checked on the decals and found that they had a reddish tint. Not sure if the ink had not dried or what happened. I do need to redo these.
This is good progress and hopefully the momentum can continue for a while.
Joe
