Yes fill them. I wouldn't count on other parts covering them.
B)
Thanks. I was kinda thinking that but, had ta ask since I'm outta my usual poison here.
Time to go study references.... :frantic
B)
I have alot to learn about armour if I want to do this Tiger up right and will ask for help when I get stuck...
Well,be free to ask your questions Ed.![]()
I'm pretty sure that you will get your answers here.
Gr,Ron.
OK fellas, question fer y'all...
Tamiya Diorama Texture Paint... How is it to work with & would it be good to use on the tracks & underside of the TIger to make it a bit dirty? I seem to recall someone here was using it recently.
Luiz (Lupanzer) was using it on his Merkava II B in the IDF Campaign for non slip panels recently.
The instructions on how to use it are simply printed on the bottle.
If you like to do something alternative check out Luc Klinker's way to do mud in his Master section here: https://www.modelersalliance.com/forum/luc-klinkers/151520-how-to-make-realistic-mud
Good luck,Ed!
Gr,Ron.
Nice start![]()
Yep I was gonna mention those seam lines ... nice start Ed ... I'll be![]()
Off and running there Ed - good progress so far!
