Soviet DSHK machinegun w/crew
Beautiful That looks awesome. Can hardly wait to see it painted Mats. Those cracks will look fantastic (y) (y) (y) (y)
I reached the top!
I will start to try out the positioning of the gun & crew tonight :hmmm
Still some work to do inside but not as much as on the outside :dance
//Mats
Some action shots :D
Overview of the diorama, most of it will be bricks from the smokestack
//Mats
Thanks for the nice comments :)
still work to be done on it, but now you see, what you before only had as an idea.
//Mats
Put a basecolour on the bricks, vallejo flat brown. went over so many times and i think i found all the small white spots! (next time i will colour the plaster)
when dry i go over and make some bricks lighter and some darker, also i will make the remains of a metal door (used for inspection) and some bands around the smokestack.
//Mats
Some more work on the bricks, and i also started the frame for the hatch (the hatch itself will be laying on the ground)
:soldier :soldier :soldier :soldier :soldier
//Mats
Thanks Terry! It's been a while since i worked on it :) now when the Torch builds are done, it's on to the next one :D
//Mats
Thanks Laura :) it's alot of trial and error but it's going forward, must make alot of bricks to fill up the area around and inside the smokestack
//Mats
First try to make plaster bricks, now i just have to cut them in length B)
Here is a pic of the jig i use to make the plaster bricks
//Mats
We are getting closer to the end of this campaign so i must focus!
Here is what i have done yesterday and today, i filled upp the inside corners with plaster and sprinkled some bricks in there B)
Then some fine sand and dilluted whiteglue after the plaster was dry, and then painted with tamiya flat brown. will be some more painting on this and some more texture around where the feets are but that's for after i put the guys in place :D
Hope you like it
//Mats
