LOOK WHAT SHOWED UP TODAY! :drool :yipee
My Gator Grip Glue and 1/200 Mask Set Thanks Gator! Very Excited 1st time trying Gator's Mask set and so far not disappointedThis will help a ton doing the Stripes
Thanks! Heavens Eagle Ive Just added this to my Word Doc of Model tips Great Info Cause i rarely have a Problem with a fresh pair of Tweezers so this makes alot of sense and will save me some money buying new tweezers, Also do you have recommendation for a pair of tweezers these excel ones seem bit cheap feeling.
Suspected. Tweezers need to have the tips redressed periodically. I really need to do a Tool Time on this but will try to explain.
Being a watchmaker I use tweezers all the time and they get abused. The insides of the tips get all chewed up and the tips can get bent slightly. This will tend to make parts launch out of them.
Take a look at the tips with good magnification. The inside surfaces should be perfectly smooth to the very tip. Look at them from the side with light behind to see how well the tips come together. If the very tip spreads apart slightly and they actually come together a little ways back, this is all easily fixable.
First off let's get the tips straightened. If they are spread slightly take each tip and press it against a HARD surface to flex it back. Take your time until you get a feel for how much it takes to line them up together. Once they are reasonably close, get two 3 inch square pieces of fresh flat 320 grit sandpaper. Place the sandpaper back to back grit side out, place the tweezers around it squeeze them slightly and draw the tips away to smooth the inside. Don't squeeze hard and don't pull them all the way off the paper. Do it repeatedly until you have a nice smooth finish on the inside surfaces.
Now check the very tips to see if they are rounded. If the very tips look like 2 balls sitting side by side you will need to flatten them. Squeeze the tip together and tap it point down on a HARD surface. Just a light tap. You want the very tip flat. If it flares a little this is a good thing. Do the bit with the sand paper between the tips again to get rid of the burr.
The last part is to dress the sides and top part of the tips down. An India stone or a good diamond hone works well for this though the 320 grit can work in a pinch. What you want to do now is squeeze the tips togetheer and work down the sides of the tips. Clean up and square up the edges of the holding surface and get them almost to a point. It is best to leave just the tinyest square tip. Don't forget to bring down the top surfaces also almost to a point. Double check how well the points com together now with light behind. There should be no gap at the tip at all.
Once you do this a few times it gets real easy and quick. It also makes your tweezers a wonderful tool instead of a problem. I know pictures would help a lot but it will be sometime late next week before I can do something to illustrate.
Oh and by HARD surface I mean either a thick piece of glass or a hard steel block. It can have absolutely no give to it.
Long explanation I know. Hope it helps!
