razordws
MMM-2020 Do335 B-6 Nightfighter
She's a beauty alright! Looking forward to your build Paul!
great plane & great start .... Paul ...![]()
Love watching your detail work.
Great job,as always...![]()
Luiz.
She's a beauty alright! Looking forward to your build Paul!![]()
Excelent!...following![]()
Luiz
What beautiful work! Man, you gotta love that jig as well. I wish I had the resources to build one like that.
Thanks for looking in guys!![]()
Today I made a supply run to the hobby shop looking for some decals, (no luck there) and came home and built a little more. Had to work out the gap and fillet where the fuselage meets the flaps. I have added really fine cuts to most all the controls where the ends are rather than just a panel line. Had to close up the big gaps where the flaps met the fuse though. Got it done and the main wing mounted.
Then it was time to do the tail feathers. The rudders are a touch out of vertical, but not noticeable to my eye. The horizontal parts though needed to be flat and level with the wings. Rather than fight with them I set up my jig and got everything aligned before glue. Then add solvent and let it dry.
Once those parts were all set it was time to add nose weight. For as small as this little beast is, it took a fair bit of fishing weights.
Now I will add the details and do filler duty. The landing gear are just pressed or tacked in place so no fighting with that. I will probably add the upper nose panel last thing before closing it and painting, just in case it needs a bit more.
Gary S. XXXXV XX XX
