hawkenstien 3...........the small stuff
in every build there is a point where i really mess up. it is when i am pushing for the end and without intending to do so, i will skip small details or rush them and cause myself issues. last night i decided that i wasnt going to do that with this build. i was going to sit down and focus on what needed to be finished prior to the final push that goes with the build.
with that in mind i went back over the last couple of days and found a couple of really good build ups for both this kit and for the 1/24 vintage series of p-40b's. they got me thinking of what i needed to do yet and to be honest there were some things that caused me a great urge to tear this thing apart and redo some of the sections to make them look better. that urge is still there but i havent acted upon it..................yet.
so back to last night. first thing i did was to make myself a list based upon the other builds and what i had with this one. once the list was created i started to work my way through it.
first up was the ammo box and the nose guns area. this area was much too barren for me. one of the builds had a wonderful series of pictures of how one builder took care of this area. i couldnt do all he did just because he worked on his while the parts were separate, but i could add just a few things. so ..............
nose guns and ammo box.
next up was to finish off the landing gear........some small details were added. they are now done.
next were the antenna mounts for the wings.
next up, the access door hinge work so i could show it open.
i couldnt forget the clear parts. these needed some things done to them and in the process i found that some of the attaching holes were needing some modification. but after some careful work with a drill and files.
and i didnt forget that i had goofed, the tail feathers were positioned wrong. so i fixed that.....
then came the nose piece and the prop.
thus ended the session last night. now mind you, i am still looking at the small stuff and a few things revealed themselves to me durring the process.
so close yet so far away from the finish line.
please, all comments, critiques, and criticism are encouraged.
joe
