hawkenstien 3...........wing work
well here i am again with a small update.
after two weeks of work ended in frustration i went to work again and came up with the skeleton for the starboard wing. i started with a cheat of sorts. i have built this kit before and in the box of builds that didnt make the moves i found the lower wing as well as the upper wings. i reglued them and then sliced them to get a profile for the spars. i then traced them out, gut them out, glued them to the cut wing parts with white glue, sanded them to the appropriate shape, and then assembled them with the wingtip to fuse spars. mind you these are in no way, shape, or form perfect. i am sure they are not 100% accurate but close enough for me. they are not square either. this is something that i can, to be honest, live with.
so the starboard wing skeleton.
used the kit wingtop to try to get the overall shape correct.
next up is to try to fashion the wing mounted gun assembly, the cable and pulley system for the flaps, the wingtip lights, and the fuel tank. thinking the upper wing will be cut on frame inward of the skeleton and the lower one frame outward of the wheel well.
what do you think of this. if it dont work i will be using the full wing and go that route.
all comments, critiques, and criticism are encouraged.
joe
