hawkenstien 3...........interior 50%
Joe, will this fuel tank be visible on the completed model? If so, I can inform you that no aircraft mechanic would allow a tank with flaking paint in the aircraft. Dirty, grimy, but the paint is protective so no chipping. Also, the aircraft's fuel tank was checked for leaks. If the pilot smelled fuel in the cockpit, a complete inspection was done.
First, spills near the fuselage drain were checked out. Spouts, fillers, and drains were wiped and checked. If the aircraft was hit near the fuel tank, it was removed for inspection. All dents, scrapes, gashes, scratches, et cetera, were attended to and remedied when necessary.
If you wish (and it's not too late), repaint the fuel tank and limit the weathering to some grime.
first the fuel tank.
painted and some wear and tear.
