@jknaus you were worried about the model of the Spandau guns on this. As it turn out it will take some butchering to make them fit so i'm using the kit guns, which still require some modification. These Gaspatch guns are just to nice to hide under a cowling. I'll use them on the DIIV or DrI later.
Test fit of the panels.
Now to rig the control lines going back to the rudder and elevator and seal up the fuselage. it's gonna be tricky because there's a seam that runs down the top, I didn't get it cleaned up as well as it should have been on the earlier Eidnecker, can't turn a blind eye to this one.
I thought I would Warren but this stuff is way way thinner than the fishing line i'm using already. And as elastic as it is it's not going to add any strength when I get to the wings. They have other thicknesses and even material. I think one of the mediums is very rigid.
I actually got some and tested it. Could not get tension on it enough to straighten it out. wasn't very forgiving. It would work for a lot of stuff in modeling but not rigging biplanes imho.Orvis fly tieing Ultra Wire X-SMall #28KA1049.
