Maddog Manufacturing 2025 Grand Re-Opening
Well, it's May and I have a short tour to offer everyone. All aboard the trams everyone!
Starting in the Motor Pool, we have some small progress done on the Iranian Chieftain. Using the pictured jig, we got the tracks assembled and installed:
full
In this next bay, we got the German Landwasserschlepper marked up with the decals:
full
Next to that is another German project, the SdKfz 9 Early version with the crane. This one got the engine and transmission installed:
full
In this next bay is an ACE kit of the British Forlite staff car. However, when I looked inside it had a paint scheme for a civilian car so that is what I decided to do. I got it all assembled to this point so far:
full
In this next bay is the Canadian Churchill. I didn't have the decals to make a specific tank so I winged it using the standard format for decals on Canadian Churchills to make this one look like a Canadian Churchill. It's done and incorrect, but this is how it's gonna stay:
full
Moving on to the next bay, we have the almost final assembly of the LRDG truck ready for paint:
full
Later we got the base paint down on the British LRDG truck:
full
More details were then painted. Note the machine gun in place of the 20mm cannon; I had lost the parts tree for the cannon, so I improvised:
full
In this next bay, I did some additional work on my Russian P-15 radar truck. A good friend told me that mesh was needed to be added to the radar dishes, so I found some that looked about right and went to work, adding it to the framework with Gator's Grip glue::
full
Here it is some hours later, all glued down and dried. This is how it's gonna look. I also had broken off the radar base from the truck and made it so the whole radar turns since that is how it's supposed to be:
full
Lastly in this next bay is the radar system for the P-18 radar truck. It took some doing and isn't lined up properly at all, but it is done:
full
Next will be some final additions and then assembly onto the truck. This radar will turn as well.
That's all for the Motor Pool, let's do a quick swing through the Shipyards....
In this first slip is the HMS Westminster, her hull is completely painted and now the photo etch details can be added:
full
In the next slip, the keel has been laid down for another British ship, the HMS Tiger:
full
Later the superstructure was added:
full
Finally in this last slip, the keel was laid for another ship. This one is the USS Alaska CB-1:
full
That's as far as I got on this. Thank you all for taking my tour and don't forget, comments are always welcome; thanks for looking in.
It's been awhile since I posted last due to a very brutal month of May for me, causing me to lose mojo and my drive to do anything. June has been slightly better which has allowed me to get a lot more done on my workbench again. I know many don't take my tours because of the length and slow load speeds; but today I have a long tour to try and catch everyone up who decides to join this tour.
Trams are waiting, all aboard for those who wish to join.....
Our first stop is in the Motor Pool where my continued efforts to achieve my next milestone have been the focus of my work.
This first bay is a German Krupp Protze truck that I started from ICM. It was extremely delicate and required some finesse. First, the chassis and suspension parts were done:
full
The interior was added and attached to the chassis:
full
While that was drying, the bed was assembled:
full
Later everything was put together. This was starting to look like a truck:
full
Wheels and final details went on next:
full
Paint was applied next:
full
Afterward, decals were applied, bringing this truck very close to completion:
full
In the next bay I started a Hobby Boss armored train car, the panzertraegerwagen. Mostly all I did was build up the main car:
full
In the next bay over, I went back to another project, the SdKfz 9 with crane. The chassis had been mostly assembled, so the main body was started:
full
Once it was mostly completed, the body was installed on the chassis:
full
More details were added, and the engine closed in by the hood (or bonnet if you prefer):
full
full
After adding the tracks, I built the crane and installed it. I then started the rigging:
full
Once that part of the rigging was done, more paint was added to bring this closer to the finish:
full
Moving, on; in this next bay we have the Iranian Chieftain that got additional details added:
full
Next is photo etch application....
In the next bay we have the final painting and detailing on the Russian P-18 Spoon Rest radar system:
full
I also made it so it will turn just like the real one:
full
In the next bay, I decided to start the PST ZIS-10 tractor Trailer since it's such a cool kit and rare in my scale. Firs was the chassis and suspension. PST is notorious for having the axle rods molded too short, so I pulled out some polystyrene rod to make the axles so the wheels were properly positioned and that the linkage connecting the transmission and differential would be the proper length:
full
full
It's almost a given that every PST truck needs this treatment...
Once that was done, the trailer was built up:
full
This truck was starting to look good:
full
I then started some painting on the tractor, and then added windows using the Micro Krystal Klear window cement since this did now come with clear acetate or parts:
full
After all that dried, the while thing got a coat of paint:
full
Moving on to the next bay, I had also started this Modelcollect tractor trailer towing a Tomahawk cruise missile launcher. Chassis and engine were first:
full
The rear parts of the tractor were added next:
full
While that was drying, I assembled the launch tubes:
full
Later I added all the panels for this and then built up the resat of the trailer to put it on:
full
As you can see it also lowers so I can position it in either launch or stowed position:
full
This is another long truck:
full
Next I added the windows and doors to the cab; and installed the cab interior to the chassis:
full
You can see I left the cab off to paint the interior and also to paint it separate to keep dullcoat from fogging the windows when I shot the rest of this.
And then paint was applied. Due to delicate parts; I opted to freehand the camouflage with a brush:
full
Wheels were added, and the cab closed up, this one is close to being finished:
full
And the launcher still raises to the launch point:
full
And that concludes our tour of the Motor Pool; since no other work was done in the Hangar or Shipyards, we'll move on to the Spaceport...
Here in the Spaceport, a good amount of work got done. First though; I found this fun little kit in my stash and figured it had to be built:
full
It just needs paint now and some details and it'll be finished.
Speaking of Flying Saucers; in this next bay we got a lot of interior painting done. It still needs some touch ups, but overall it's close to done. Here's the four views of the interior:
full
full
full
full
Moving on to the next bay, we got the crew together, (sans Chewie who was out scrounging parts) for the Falcon, along with a few interested Stormtroopers:
full
Meanwhile the Falcon herself got the top and bottom hulls mated together:
full
Afterward, all the side detail was added all around:
full
full
Some of the crew decided to try out the cockpit seats:
full
All the final details are on this and she is now fully ready for paint:
full
full
And that concludes our latest tour of Maddog Manufacturing for this month. Thank you to all who took the tour, comments are welcome.
Thanks to this past Hobby Day weekend, I have more progress to show, enough to bring out the trams again and load them up for another tour. All aboard as we take another tour of the Motor Pool this week.
The first model we worked on in this first bay is the Iranian Chieftain. We got the photo etch on it to prepare for painting:
full
full
Later it got a basecoat of the sandy color it will be sporting:
full
Finally, it got the skirts and a replacement barrel. I lost the original somehow, so I found one that looks close enough. I refuse to sideline a kit to wait forever for one lousy part to reappear! Other detail parts were added too:
full
Here it is glossed up and ready for decals:
full
Moving on to the next bay, we had the German panzerjaegerwagen languishing for a bit so it was pulled out and the turret built:
full
A base coat and camouflage pattern were then painted on:
full
Followed by Gloss and decals:
full
Since so many of these were so close to finishing, I pulled out more to start. This first one is the ancient Morris Quad and 25lb gun with limber which will be added to my Canadian Army in honor of a fellow Braille Scale modeler from Canada who passed away recently. I started with the Quad, even adding the driver to it:
full
Later I continued to work on this; enjoying the nostalgia of the build and before too long; I had this:
full
Yeah that will be ready for paint soon. In the next bay, I started the ACE kit of the Salamander Crash tender I bought in San Diego. I started with the interior as always:
full
That must have been interesting to drive from the center of the cab. Next the rear sections were built up and added:
full
Those were tough to line up but I got them looking fairly close. Next I painted the interior so I could close it up:
full
Roof, sides and front went on next, along with some filler in certain places:
full
After some sanding and prep, this got a coat of Krylon glossy apple red spray can:
full
I then decanted some and hand painted the frames on the windows, which I refined later:
full
Next this got almost all the last detail parts before decaling:
full
In the next bay; we started an ancient ESCI kit of the Leopard 1A2, which had markings for an Italian tank. So, we started on the hull of my new Italian tank:
full
While that was drying, the basic turret was built:
full
Later on the bogies, drive wheel and idlers were added and the tracks installed. The extra parts for the upper hull were added and then the whole thing cemented together:
full
Sometime later the remaining detail parts for the turret were added so now this one is ready for paint:
full
Finally in this last bay; we managed to get started on one of my raffle prizes from San Diego; the Dragon Hummel. This one is going to be Syrian, thus completing the entire inventory of German vehicles in Syrian service:
full
And that completes this tour of the latest Motor Pool progress for this week. Thank you for stopping in, comments are welcome.
