:drinksThanks Guys,
Have taken a quick break and cleaned the work bench up.
Tomorrow is the beginning for the Archer decals to go on the instrument plate and dash .
All day Archer :cheer:
Michael![]()
:drinksThanks Guys,
Michael![]()
Yes Bob,
Always apply the decal wet .
Sometimes when the decal is applied by rubbing onto the plate it does not sit properly and tends to tear at the edge.
I think in some respects Archer should look at having the decal packs being supplied wet because they are more likely to last with the application of a wet decal onto the subject better than a rub on decal .
Have used a lot of the Archer decals in the wet method and this is and always will be my preferred method.
Depending on the subject sometimes if it is a large area a rub on transfer may work but when you rub on the transfer onto the subject you do not know if the decal is sitting properly on the subject .Because you cannot see it ,
when it's on there is no going back .Where as with the wet method , you can position properly and you are not tearing the decal, also you can reset the decal if it's not in the right position by using the wet method .
When you like a preferred method of choice you stick with it .![]()
Michael
