When i bought it i bought the right to moan about it as well :laugh:
section 28 and 29 clearly show the undercarriage wells being assembled into the bottom half of the wing however by section 30 they are clearly assembled in the top half of the wing. You can't assemble in the top half of the wing because all the positioning points are on the bottom half but you cant then add all the little webs and parts in section 30 while its assembled in the bottom half...
Maybe i'm missing something :laugh:
This explains the improvement in print quality but if it doesn't stick to the metal it is useless! I hope I don't have that issue. By the way, the fabric belts are by HGW with Eduard hardware. RB Productions also has a set of fabric belts with PE hardware.
Problem is Saul, the opening in the underside of the wing is much smaller than the interior outline of the wheel well so once you have assembled the top half to the bottom half there is no way you would get parts H15 or H16 in position.
