Not and airplane modeler? Horse cookies!
Your work is superb.
Moon puppy (Bob? Sorry , I don't remember your name, sorry!!) I have doubt for the colour of antenna wire :idonno . I have search info on internet and I make question to airplane modeler. The responses are various, from steel at copper, this last is most probably. I thinking the solution and I will post the new photos.
Thank you so much!!
Mike
:cheer: and the co9rrect answer to the antenna wire is :
Although I have seen several modern day restorations that have used common safety wire for their antennas stainless steel wire was not normally used in military aircraft in WWII.
Army aircraft typically had a solid wire that had a steel core for strength and copper coat on the outside for conductance. This wire was bent around wrapped on itself with a specified number of turns for terminations and splices for lead ins.
Navy aircraft used a braided antenna wire sometimes made of a phosphor bronze and could also have a cord inside for additional strength. The braided wire would be terminated with crimp type fasteners.
At any rate, it probably looked dark after a bit .
Love it, great addition with the insulators at the attachment points of the antenna. what did you use for that Mike?
Next, how about something in one of our Campaigns?
https://www.modelersalliance.com/forum/current-campaigns
....yep, much better. Pretty d*mn close to perfect![]()
Ian
