Everyone, thanks for looking in ! No pics today, working on gear doors. Found the nose door was NOT to my liking. My friend Martin is sending me another. These were assembled a few yrs ago, and looking at them now, I see lots of mess ups and will have to redo the PE. I do have another Eduard set thank god !. Will post when I get things worked out....Harv
Nice to see this one's back been missing it & you Harv,![]()
:woohoo:
:woohoo:
How are you my friend ? You do cross my mind once and a while !.....Harv
Finally getting to the "dreaded" LG doors. I have been dreading this step for a long time. Here is a pic of what we are working with.
Next pic is what the door looked like before fix
None of the PE lines up, well maybe one piece. Removed the offending PE parts and put new ones on. But this time I only installed the piece that is on the door. I then glued the door on and then glued the tinny angles on the side of the well. After dry, I added the "hinge". One door is now done and took about 4 hrs. Only have 3 mains and 1 nose door to do
If you want to see what they SHOULD look like, check ChrisS build . Much nicer.
Pic of installed new door.....Harv
