1/24 Aluminum Gator Boat
Thanks guys. These patterns are tiny. It took a good bit of fine tuning my cutter to get them to cut without tearing the patterns up. It is a delicate balance of speed, pressure and depth of the cutting blade.
I got the camouflage patterns sprayed yesterday evening. I brought it outside to put a coat of flat on it and the flat fogged.
I also got the fuel tank made. Next up is the battery.
Put a clear coat on it and see if it comes back around.
Did you think about using brush for the non slip inside? Stiff one.
Great news! I shot the hull with flat again and the color came right back. The motor also came in today. I need to strip it and do some body work though.
