Spent a good deal of time with the Marder in the paint booth today but before we get to that, there were some small little details on the hull that needed tending to. They included the large fighting compartment lifting eyes (H9) and the tiny tie-down loops in PE (P33). There are 16 of the PE loops that go around the top of the compartment and these were glued in place using liquid glue and Bronco's conveniently molded locater holes. These are quite delicate and Bronco provides 6 extras on the PE fret as back-ups just in case. I also added the spare track holder to the hull nose to round things out.
With that out of the way, it was time to finish the hull painting. I masked offer the interior on the compartment and the gun with blue painter's tape and set to work with the airbrush. Primer coat of MM Italian Dark Brown followed by the base coat of 50/50 MM Light Gray/Panzer Dunkelgelb did the trick.
The camo pattern came next. I used MM Khaki for the green portions first then added the red-brown using a 50/50 mix of MM Leather/Military Brown. After correcting for a little over-spray here and there, a mist coat using heavily thinned base coat was applied to tie the scheme together.
While that sits and cures up, work will continue on the tracks and other remaining equipment details.
Crisp and tight Bill. :coolio
