jknaus
Administrator
If the scrapes are on the outside, before you try sanding sticks try some colgate tooth paste. The white stuff, not a gel. Use a soft cloth and just polish as if polishing boots. Less chance of causing stress fractures. Then clean well and use future. If you use sanding sticks while its mounted you might end up in a worse place. If you can take it off then fill with plasticine and the stix would be a better option. Just my thoughts on it.
