I'm at a loss for words to express how incredible this is. Way to go and I wouldn't change a thing. That is very smart of you to keep it as is.
Man, I'm overwhelmed! This is far and away higher quality and skill than I could ever dream of doing!
You are the Master!![]()
Wow, that is amazing, Laurence!![]()
Man, soldering thin brass on thick can be tricky, right Eric?![]()
Good luck, looking sharp so far.![]()
That it is!!...![]()
...man Laurence that mast is off the hook!!!![]()
Fantastic Laurence!
This is such a really cool build! It makes me want to build one!
Bob
The trick to soldering tiny parts to each other is to pre-tin both parts. Then all you have to do is hold them together and heat them till the pre-tin flows and bonds. There are quite a number of soldering units available for around $100 that have the capability to solder with hot air. That will work with pre-tinning and solder paste.
This is just freaking amazing Lawrence! Nice work.
I am inclined to use two parts epoxy resin - a very small amount, around the joint, for that extra strength that is always good to have.
Laurence
