very nice less thanks for the update not be interesting to know the recipe for your custom rubber formula unless its a top secret
Swordsman,
My custom tire mix is made from the following paint colors...Testors Rubber(in the small square bottle), flat white, and tan.
When I mix up a batch of this paint color I start out with adding Rubber to some flat white, the darker Rubber color will quickly turn the flat white dark and that's why I don't add the flat white to the Rubber color of paint because it will take much more of the white paint to lighten the Rubber to the shade of paint I am after and will waste less paint that way.
Sometimes I will add some flat light tan to the custom mixed rubber color but not more than a drop or two.
Matrixone
This first picture shows the back of the prop blades, a great many Bf 109's had the rear of the prop blades with a lot of paint worn away near the tips.
