Tankbuilder
All Righty ... What are you doing today ?
Well I've been reconstructing cut off access panels from my 1/48 Hobbycraft CF-100 Mk.V kit that i'd scavanged some parts from.I fitted thin Evergreen strips or thin plastic along tthe edges of the panels, let then cure then carefully ground and sanded them to fit back into the fuselage. I'll be banging this together into a wheels up model and I might backdate it to a Mk.IV but I don't know if I want to build two gunsights. I've orderd a resin CF-100 "CLUNK" cockpit update set for my other Mk.IV model but that set doesn't come with a gunsight.
Look at any images of the Mk.IV and you'll see just how prominent that gunsight is. It really stands out.
Cheers from Peter
Cheers from Peter
