Dragon M48A3 Mod B Viet Nam 11th Armored 1969
Well, I took some photographs this morning, hopefully they will help and not be too late:
Extreme close up images like these help me find gaps which I will fill with thick CA at this point.
The seam seen at the left is hidden behind the mud guards.
The engine deck needs work in the form of 'cake frosting' welds, done with Gunze Sangyo's Liquid Putty, and casting surfaces for which I use Mr. Surfacer 1000, also from Gunze Sangyo.
Attach the piece to eliminate the seam and add casting texture. I need to add the casting marks (I chose the front one, option 1) and then add a second coat of Mr. Surfacer 100.
I blame Mr. T's M103 build for having me start this kit!
:evil:
Hopefully, it will end up like this:
Reference photos :good:
this is a M48A2 engine deck
M60 Slick engine deck
M48 lower hull details
M48A2 turret details
M48 turret details
More progress last night
I have to say my biggest disappointment with the kit is the molded on storage box handles :(
That is strange especially since Italeri's Grand Old M47 has them separately. If you want flat and lifeless, there are some from Eduard but I have a set from Tiger Models for my build:
Very very cool . Love seeing how you bring this up a few notches in detailing to a whole other level. (y) (y) (y) (y) (y) (y) (y) (y) :notworthy :notworthy :notworthy :notworthy :notworthy :notworthy :notworthy :D
I took advantage of getting off with a half shift tonight :ro:
added casting texture, casting marks and numbers to the gun mantel
also drilled a hole in each of the search light mounts
I started to scratch some new storage boxes for the fenders. Not that the kit ones are wrong. I just find it hard to do damage to them. (more to come)
Last is making a filler piece for the bottom of the turret race.
First the spot that needs filled
Next I rubbed the edges with a color pencil
I then use scotch tape and cover the spot
Taking the tape and transfer it to sheet plastic
Cut it the piece out, pull the tape and test fit. The part still needs some filing, but hope someone has not seen that before. :good:
