Tree,I never know when you're going to pop in but I appreciate it when you do.
Pup wanted to know how I make my hinges so this morning I assembled one and took pictures as I went. This is just the way I do it and i'm sure there are many other ways just as easy.
First thing I do is curl up the tabs with a dental pick.
When you lace the two halves together it looks like this.
I tape the plates to the bench and lay the hinge wire in the trough formed by the tabs and tape it down.
Now i'm ready to start forming a hinge. First I bend the first two tabs on the ends and the center over the wire so the wire stays centered.
Then I fold the rest of the tabs over the wire to complete that process.
Next I place a steel straight edge on the back side of the hinge and press a small flat blade screw driver on the ends of the tabs to tighten them up on the wire,turn it around and do the other side.
Remove the tape,pull the excess hinge wire out till it's flush on one end and snip it off flush with the other end.
Hey we've got a hinge to be proud of.
That's how I do it,simple ain't it?
Tony Lee
