I have a question now. Where could I find an engine buck or stand for this kit? if I am going to display it I need one as the only ground stuff this has are a crew ladder and the fuselage stand for the aft part of the fuse.
Are you planning on displaying the engine separate from the aircraft? Are you willing to make all that internal framework as well as the air intake trunk? I know the kit provides a fuselage stand to allow the engine to be seen still mounted in the fuselage but removing it requires either a complete internal structure which is seen or, if you planned to have the front an rear fuselage together, replacing the compressor fan and bullet fairing as well as everything viewed from the rear.
If you are that ambitious, I think I may have what you would need.
