Thanks again guys!![]()
Ian,
You should see the RVD band by Monday. :laugh:
Mike,
Yes I did almost all the camo free handed, its so much easier than doing a lot of masking. As can be seen in some of the earlier posts I did mask off the fuselage whilst painting the wings, I am not worried so much about overspray as I am about having safe areas to grasp the model during painting, I really hate leaving fingerprints in paint that is not all the way dry so I play it safe and paint the wings and fuselage separately.
The Fw 190D-9 had the rear half of the wings undersurfaces painted BMF. I did this by mixing flat white with Testors Chrome Silver to produce a bright metal finish without it being too bright, I sprayed this on in a cross hatch pattern to represent some of the rivet patterns. I was not concerned with being too precise doing this since the clear flat coat and weathering will tone it down to where it will barely be seen and give the illusion of a rivet pattern being there.
The landing gear doors and flaps were also painted and nearly ready for weathering.
Matrixone
I'm still in awe that you guys can get mask straight on a complex surface like that. I know it sounds simple but I'll be damned if I can do it.
