Bob,
This Me 109E model will only be seen from below so I went ahead with some dried mud splatters from the main wheels. The upper surfaces won't get any weathering since it won't be seen anyway.
The painting of the Bf 109K-4 tail is now complete, this was a little more work than I had wanted to put into it but I do like how it turned out.
The dark green RLM 83 spots were done by looking at my reference photographs and carefully painting the outlines of the spots to match the photographs, than when it looked good enough I used the same paint color in my airbrush and filled in the center of the spots.
If you look closely I made the edges of the spots slightly soft looking to match the look of how many of these of these tails looked after they were sprayed with the stencil...some tails painted with the stencils had hard edges but most appear to have a slightly soft edge where the stencil lifted a tiny amount creating the soft edge between the two colors.
Here is a 109K fuselage that was found near a forest aircraft assembly center just after the war ended. There were many fuselages found at this site and the tails were all painted in a similar fashion.
...here is another snap of one of the captured 109K fuselages, this is not the same airframe as seen in the above photograph.
I just need to paint the fuselage and the major work on this model is done.
Here is another color photograph of a K-4, note the colors and pattern on the tail. :hmmm
Matrixone
