Thanks once again Luiz.
Painting of the upper surfaces on the Me 109E has started.
The Matchbox painting instructions looked sketchy so I looked up the factory camouflage pattern for this aircraft and sure enough Matchbox was wrong, the correct pattern is Type 5 and that's what I am going with on this model.
As usual when I paint my models I paint the wings first and let them dry before painting the fuselage, doing this gives me a safe way of handling the model without any risk of getting fingerprints on wet paint.
Monday morning I had a surprise visitor, a much larger than usual spider was in my carport and just sitting there out in the open...the type of spider was a funnel web spider and they rarely go outside of their web so I thought it was in the process of dying. I ran and got my camera to get some snaps of it and needed to move the spider to a place with better lighting and used a broom to carefully move it and took some pictures and wanted to adjust the setting on my camera and after making the adjustment I looked down again and the spider was gone, a split second later I found the spider as it was starting to crawl on my shoe and very much alive.hmy: Since this type of spider can cause some harm to humans with its bite I killed it instead of moving it away from the house.
Matrixone
Thanks again Luiz.![]()
The yellow I.D. markings have been painted on.
You might notice the yellow is rather patchy looking and that's intentional. Many Me 109's (and Me 110's) used either yellow or white distemper paints during the B.o.B. for the I.D. markings and these paints were not very durable and would wear off quickly and this model was painted to try and copy that effect.
After masking off the areas needed a mottled finish of flat white was airbrushed on first and than the yellow was sprayed on also in a mottled pattern.
The yellow paint I used was RLM 04 with a tiny amount of red added to it, I did this because after reading a number of the eyewitness reports of downed Me 109's during the B.o.B. the yellow markings were sometimes described as orange in color and this could very possibly be because the yellow distemper paint was a deeper shade of yellow than the standard marking color of RLM 04. :idonno
Interesting tidbits ....Thank you . Cheer, Christian B)
Matrixone
