A little bit of an update on this one as my "lab" is still in a state of chaos.
Don't get too excited!
Here's where she sits now. I've pretty much finished the filling and sanding of the fuselage and had put some more thought into the aluminum finish. I've pulled off the few test pieces of the aluminum tape (with the exception of the rear tailplanes).
Up to this point, I had been using only aluminum tape and then adding rivets with my rivet wheel after it was applied. Didn't look too bad and I had wanted to try some other types like Bare Metal Foil.
After a night of blindly searching around the net I stumbled on this thread over on LSP (if you haven't seen this yet, its a great build!)
http://forum.largescaleplanes.com/index.php?showtopic=38905&page=23
Rich, the builder, had used pewter sheet to make the skin of his B-17 (and a fantastic job he did). So, it got me thinking if I could do the same with aluminum foil and tape with this build.... Time for a test!
I tried making rivets on the backside of both....
and they actually come out quite nice!
I think it gives a more realistic look and there might be a chance to actually make the skin look a little stressed too.
The only problem with this is that it might be hard to match up rivet lines with each piece (as it will have to be done before its applied to the model). Anyway, I'm working on a solution!
I tried a small piece on an old float and it worked ok (though its hard to see in this picture). I even tested how paint would stick and it was very easy to add scratches and wear points too.
Also took a moment to see how decals would stick to the aluminum, no issues with a little Micro set and sol!
that's all for the moment!
