Wingnut Wing SE.5a
You can see what i mean by varying the coats you can change the colour depth and of course the undercoat gives you even more shade options. what first struck me with this paint is was how fine the pigment is, on a really smooth surface it goes on like glass. Your colour looks really good , i wonder what it would look like with a light green or dark green under coat. :cool:
Add 8 more bucks to that order.
:frantic:
I really like how the zenith shading on the fabric ripples came out, disregard the overspray, my CDL mix was behaving badly.
The prop with the heavy acrylics.
Tamiya Dark yellow or buff for the base, I forget and then burnt umber and something else...sorry didn't pay attention to the name, the lighter shade.
Sorry to see the paint spill Bob. It always hurts when there is a waste like that. At least it wasn't all over the build so that is at least the other thing that could have happened.
I have not had too much of an issue with the paint, but the glue was a whole different story. I have an Ambroid Pro Weld bottle and a bottle that was filled with Zip Kicker. They were both the same size and fit perfectly into these plastic connectors I found at Lowe's. I added a small wad of Silly Putty into the bottom of the hole and pressed the bottles into it. I can remove them fairly easily, but they don't move unless I "MAKE" them move. The lids twist off easily with one hand and one side holds a paint brush for the glue, and the other side has a couple of tubes for some metal dippers that I use to apply the accelerant to CA.
Well I'm kinda tickled that my home brew CDL of white and dark yellow is right in the middle of MRPs versions of CDL and bleached CDL.
Seal coat will be put on this and then some washes, should blend it some.
