Wingnut Wing SE.5a
Deflect the rubber indeed LOL. Ay ya yai. So that's what the kids are calling it these days!
This plane looks so stinking good!! Makes me want to put the Mustang away and start my Glouster.
Getting this wrapped up, rubber or rudder be damned.
I added a small brass washer between the back plate of the prop hub and the motor shaft, seemed too close. Waiting on that solvent to cure before attaching the prop to the hub, hopefully the shaft still spins.
I got some weathering to do, not much just mud splatters.
Added a wire down from the trigger of the Lewis, just draped down in the cockpit, there's another line that needs to be run from on the front of the cooling jacket to the rail so the gun could be lowered, that just goes down the top of the wing with a loop dangling down.
What I really need is some better lighting and photo box!
Well I think I'm calling this done!
All that work in the cockpit and this is what can be seen.
Only short comings I can mention is the attachment of the control surfaces, there's little if anything to attach the parts to the surfaces.
Thanks for all y'alls input.
That really is pretty exceptional Bob. I have looked hard and i can't fault it :). The rigging stands out as does the underside weathering.
The Potus kit for my ship came with miles of this elastic thread, its not something i have come across before but having now seen it i can see why you are so keen on it, Top notch mate, will look great along side the little red Foker :)
Thanks guys, you really have to think about provisioning for rigging way earlier than I did. I had a lot of drilling post construction that I needed to do.
Fresh CA helps also!
