Houston................we have a problem ..
The body work seems to fit pretty well given the number of parts and the opportunity, given the constructed frame, for things to go very wrong
Getting the engine firewall positioned correctly seems to be the key as its the datum point for the other panels as far as i can see...however.
The rear panel engine cover seems to fit ok on the top but it should pivot at the rear and the hinge mechanism is way out, maybe as much as 1/2" or 12mm ?
This from another build on another website
-- The hinges for the doors and rear engine lid are much sturdier than past kits, and we are all used to misalignment of 0.5 or 1.0 mm requiring some adjustment. But the hinge for the engine lid was too high, compared to the location on the subframe where it attaches, by 11 mm (7/16" in the photo). I fabricated an extension for the hinge; it is possible I got the rear subframe wrong, but everything else in back lines up very nicely, so I doubt that I was off by a whole 11 mm.
So this is not me but forewarned is forearmed.
