I like the dirty look Bob, enhancing the detail really stands out the raised sections.
Michael
Thanks Mike,
Hopefully, the detail will pop even more when I do the highlighting!
Bob
Michael
Guess I'm on bump detail again, looking awesome Mr L.!I've began to weather the K5 E Railway gun. I base coated it five years ago, so the finish is about as hard as it is gonna get! Iron Mike, (Mike Trent), had built a Panzer 3 in dunkelgelb and I liked the finish a lot! So, I asked him what colors he used to weather it. He gave them to me and so I'm using them plus a few more. I still weather with old school methods because,...... well, I'm old school!
I started with the two trucks, front and rear, on which the massive gun is carried from place to place pulled by a locomotive or one of the small diesels the Germans used for lighter jobs. I began with my old raw umber artists oil and rectified turpentine wash. It is a process, especially on a yellow base coat, in which you have to close your eyes, grit your teeth and just do it. It never ceases to put the fear of God in you. It goes on and looks just terrible. But, have faith and pull up all the patience you can manage and here we go.
Then I place on a coated sheet of cardboard, (If not coated, the liquid will soak into the cardboard and dry very quickly), . a strip of the paint about an inch long and then, using a wide filbert brush, (a number 8 or 10, I mix it on the cardboard pallet thoroughly until it is the consistency of whole milk. Then, using that brush, paint it on an area about 2 inches square, more or less, at a time. That's the scary part. It will look like you just painted it an ugly brown color that is not even translucent.
Here it is a bit closer.
Then, using a clean T-shirt, I begin blotting, (Not rubbing), the raw umber mixture until it only remains in the recesses. The raised parts will be a bit darker yellow, but, after a few hours, it will lighten as well as flatten out, leaving a much more pleasing contrast between the raised and recessed areas.
Here I have done three of the wheels and housings. As I said, looks scary, doesn't it?
Here I have washed and finished the entire rear half of the truck. I get all I can using my finger underneath the cloth, changing places frequently, as I blot, then after It is mostly blotted so there is a thin coat of the raw umber mixture left, I use a Q-tip under the cloth to get at the more recessed areas. Using it alone will leave unwanted lint.
But, after the T-shirt is finished with it, it doesn't look so bad, and, it will look even better left overnight to fry.
Another view.
Then, I finished the entire truck.
The other side.
Compared to the unwashed truck. You can see the washed one is several shades darker. That's the object!
Another view.
Tomorrow, I'll begin some dry brushing, and post as I move along. Then pastels, chipping and rusting. This vehicle sat in the weather under the bombed out Train shed for months so it would have extensive rusting.
Thanks for looking in!
Bob
@Iron Mike so what were the colors? (notice the @ user name thing, you can tag people who might miss a comment)
Looks great Dad![]()
Thanks Warren,Fantastic Bob! Great paint work and an interesting rail gun!
Thanks Mike. More than just affirmation! I knew I would likely not use the same technique to apply those colors, I'm old school. but, the most important information I received from you was not only the colors to use to get the finish I wanted, but, just as importantly to me, were the colors NOT to use! It had been so long since I weathered that color, I didn't want to screw up a big project like the RR Gun!Looking great, Bob! I was glad to help and flattered that you liked my StuG so much, but I suspect my input was just affirmation. Colors? Dark pin wash, rust colored chips, dust and mud colored pigments. There's more to learn here than from me.
Thing is while they were used and banged around a bit, there wouldn't be much more than a little rust or very big chips. It would be weathered a bit, but no salt or much in the way of corrosive stuff on these. Wear and tear, but that is about all.
Looks great Bob......yeah what are those colors you mentioned.
Thanks Bob, always nice to expand on techniques. I especially like the ink pen idea do you have a picture of the pens/aplicators?Thanks Ian,
The colors Mike gave me to use on a Dunkelgelb base coat were; a Dark pin wash, rust colored chips, dust and mud colored pigments. I used all those colors but, in a different way. Regardless of how you apply the colors, they're still the same colors! Right? I used a raw umber artist's oil and rectified turpentine wash, which is the exact color of natural dirt, dust and mud. I used raw umber and burnt umber pastel sticks, ground into powder. Pretty much the same as pigments. Instead of a pin wash, I used two dark ink pens, Black and dark brown in the seams and creases. (I use the numbers .01 and .005 pens available in art stores). Then I used artist's oil Burnt Sienna, (The color of rust), for the rusting, with a bit of Burnt Sienna pastels to finish off the rusting.
Basically the same colors that Mike used, only different in the application and mediums. Actually, these are the same colors I use for Panzer Gray, Olive Drab, Camouflage gray and other military base coats. I had forgotten due to the length of time since I worked on that color. Hey, I'm old!
A rose by any other name is still a rose!
Bob
