Old Dog
DH-82A/C TIGER MOTH 1/32 (Down To The Wire)
I haven't used tube cement since I was a kid, I thought they took all the good stuff out when sniffing the stuff became vogue. I think you need some thing hotter solvent wise like Tamiya thin or Tenax7R. If what you are using is not melting the joint a bit you are not going to get a solid bond. CA tends to be too brittle for joints that are going to under stress like when you do rigging. Best CA I've found is Gorilla's stuff, it has an additive to make it a bit more flexible but I still think you need something hotter than tube glue.
Dat beast into submission Gerry!!
