V100 - Opinions / suggestions please
Ok I'm going to be the wet blanket. Weathering and the the amount depends on where you are depicting it so the color and the amount looks fine, however it does look inconsistant. Not that dirt/dust on a vehicle is symetrical it does collect in simular places. If you are going to put dust/dirt around one vision port it will proabably collect around all or them. It will collect around bolts, mounting brackets, and almost anything that creates and angle against the hull. The wheels and tires seem to clash with the rest of the vehicle. That is to say they are too clean and shiney. Of all the places where dirt will collect the wheels and the underside of the vehicle are the most likely spots. These areas need to match the weathering of the rest of vehicle, but more than likely these areas will have more heavy weathering.
You are doing good, but keep at it.
Here are some period pictures. They should give you and idea of wear and weathering of the V100 in the field.
B)
B)
