I have a question of you guys with the wings since I'm not up on either WWI or AC. I was thinking of toning down the color a bit with a filte/wash after I seal everything again. Is that a good idea or the stupidest thing you've ever heard? I really don't know. I assume the fabric would wear and fade a bit, but not sure.
I would think they would fade greatly, now would be the best time to do your weathering because once you have it rigged up it's going to be hard to get in between the rigging lines and have consistent weathering pattern.
Another question: I got the turnbuckles. I don't know what I'm looking at, so 1/32 seems okay with me to proceed. I plan on gluing the EZ line into the holes on the underside of the wing before assembly, then trimming and connecting to the turnbuckles after assembly, and CA'ing in place. I'm only going to use them on the bottom (meaning top of lower wing). Is that the way to do it?
Call me crazy but I ended up actually tying the lines on the turnbuckles. Yeah it got tedious! But I tied off both ends of the line a little short of the run. Attach the first turnbuckle and then stretched it the attachment the second one. Should be nice and tight and hangs very naturally out of the eyelet. Be careful of the angle the turnbuckle leaves the attachment point because of course it will be at the same angle that it's being pulled on. Be mindful of the eyelet, might want to give it a quick sanding to make sure the line swings free of any burs.
Jeff this looks amazing...rock on Bro! :drinks
