alex wence de leon
...continuing
Line up of fabricated parts:
wheels, fenders, engine cradle frameworks and springer back fork.
Shaping and tapering upper fork section with miniatures files.
Fabricating and fit-up, springer front fork suspension.
Springer Front Fork Suspension fit up.
Much alignment and smoothing to be done beyond this point, but satisfied with progress so far.
Further alignment of miniature 'springer' front fork suspension.
Fitting top tapered springs.
Fit-up: Neck tube.
There is a slight rake & stretch and will monitor that fact during further fabrication of rolling chassis. Adjustments can always be done at a later time.
The key here is maintaing the horizontal frame tube & engine V, parallel to ground level.
Neck tube installed on frame.
Inner & outer springs installed on front fork.
Good progression with the miniature "JD" rolling chassis, so far.
to be continued...
Fit-up: Neck tube.
to be continued...
