White_Wolf
Off we go, my first campaign here - here's the photo
Fingers crossed that it goes well
Verlinden does a great super detail set for the Willys mate.Plenty of resin an PE to make it look busy,set number:1275.Got one for a build I will do one day. Gunna be![]()
OK then, I'm not going to do the Jeep I was thinking about...
Looking forward to this Wulf![]()
Cannot go wrong with a Tamiya Jeep !!
Ian
Ian
Hope so Ian, thanks for the vote of confidence![]()
This is what I intend this to end up like - a little vignette
Frame is next for "mudding". Started before attaching the two parts because it's more difficult to put the pigment where you want it with the frame in place.
Silvering - I found a tip a while back on a site I can't even remember :smack
It says that using a VERY thin needle you do some pricks on the decal and then, using softener with a flat soft brush rub it, but gently again. Have tried it before with satisfactory results. Weathering will mask some of the silvering as well, what remains after the "Operation Needle".
Thanks for the feedback though, very pertinent observations![]()
