Flatcoated with Testors rattlecan - pushed my luck and did this in very breezy conditions oputside and not much sun - we have lovely rain now :evil:
my panel line accent didn't work as I had hoped, the flatcoat toned it down nice and in places too nice!!
When attaching the gun sight I found that if I placed it as Tamiya's instructions on the kit pit tub, it was BELOW the forward pit frame - line of sight would of been into the nosecone......
I thought at first it was the Pe set that caused this, but all the Pe set did was attach to the plastic IP that has a cutout for the gun sight.
As you can see the kit plastic part - and it has a set attachment point in the nosecone
I attached it this way
Tamiya shake and bake?
I don't think so
more like drop and burn...
here is the nosewheel
The arrow on the right is the edge of the slot - where the arrow on the left shows the one piece part edge of the gear leg which is supposed to slide into place - Not!
As you can see from this pic you can work out which angle I had to file off to make this slide in
Some Pe detail I forgot about - :bangshead:
Gear doors on and a piece of Pe for the nose wheel doors that must be the most flimsy piece of all time - yes it does need straightening a bit more!!!
And to top off tonight's efforts I was trying to remove a blockage in the top left gun barrel - which decided to let go and disappear into the now sealed nose section
That's all for now - see you all on the Pe funny farm........... :gogo
