paddy
Trade secret alert
Take a small length of 0.2mm tinned copper wire or similar and hold it between finger and thumb like this.
Small electric drill or electric screw driver with an L shaped bit of hard wire like piano wire in the chuck. use a dia the same as the eye you want, this in 0.5mm
Hold the wire tight and run the drill at a very slow speed, about 1 rev a second for starters 60rpm
you can cut off the excess. i put all the loops on a length of hard wire and cut them all the same length.
