finey! :cheer:
take some of your colors: red, white, yellow and deep ochre
and mix your flesh color with them on a palette - use only a little amount of red, mainly yellow and white! when you reached the tone you are satisfied with, add some of the ochre!
before you start the mixing think of where the figure will be and in what condidion - summer or winter, desert/pacific or BoB, hungry/desperate or well fed!
you won't need the turpentine now, not in this step!
apply this color mix to the flesh parts of your figures with a #1 round brush very thin! very thin is the key!
when done so and after having cleaned up the brush focus on the figures shirts and uniforms! we paint from the inside to outside!
again take your #1 brush and mix your green for the coverall! not too dark, not too light! a tone right in between! we will start to apply shades and lights from there!
simultaneously take a smaller brush (i took a 10/0) and mix the shirt color from white, yellow and ochre!
with the smaller brush paint the shirts and try not to overpaint the edges too much - again better apply a thin cover! same with the uniform! take the #1 brush and apply a blob of green that you spread out as thin as possible! you will notice that the streaks from the brush will vanish the thinner the applied paint gets!
make sure that the paint reaches all recesses and no spot is left uncovered!
