Here is a couple Focke-Wulfs that were started the other day, the Dora is being built from the 1/32 scale Hasegawa kit, and the Ta 152C is from the 1/48 scale HobbyBoss kit.
Here is the markings I intend to put the Dora in.
I have the EagleCal sheet for the markings of ''red 18'', sadly the decal sheet does not have the distinctive small black 17 in the circle that was on both sides of the fuselage so I will have to come up with something. :idonno
I had to modify the gun cowl by filling some panel lines and removing the small bulges used on Mimetall built Doras. The matching bulges on the engine cowl were also removed.
I still have to add the small round bulge to the rear of the gun cowl as seen here in this photograph of ''red 18''.
Here is the HobbyBoss Ta 152C, not much done on it yet except for cockpit construction but I am impressed with the cockpit detail, its quite good and should look okay after painting.
Not so impressive is the shape of the propeller and fin/rudder...they look a bit off to me. :huh:
How can HobbyBoss get some of the simple things like the fin/rudder and prop blades this wrong when there were a number of photographs and drawings available and has been for years.
Matrixone
Matrixone
