Re: Classic Airframes 1/48 Do17Z
Im leaving out all the seats as they protrude to high and the nice resin is so very thin, they can be glued in after painting, the rear gun support and control column can be left out too, ......... :bangshead:
At the moment I'm adding a little more detail to the pit and gunners areas, there is no throttle controls so the parts bin is getting a work over.
small update
( the top pit part is not glued on)
The IP was an absolute bugger to glue in, I put it on the opposite side where the destuctions called, it fitted better, a care bending was needed also.
As you can see the engine nacelles fitted almost perfect - gap negligible, just a fill with a thin line of Ca closed it up
The nacelles have four lugs, the cutouts need just a little cleaning out, they snap in tight so be careful you don't break them, i broke one.
Also you need to make sure you have the correct gear assembly firewalls correct for port and starboard, when right they slope correctly for the wing fit.
Not much filler needed, I rarely use it but you can see where the prob areas are
more a bit later.
