Re: Classic Airframes 1/48 Do17Z
Great pics Hubert thanks! but all academic now - decals on, flatcoated, weathering started so it is how it is.
One can only work from what info one has, especially when the scheme is marked in an aircraft book :drinks
If anyone does get hold of this kit - leave the tailwheel, bomb bay and gear doors off til the last steps............ you have been warned!!!!!! no need to tell you why.
going by Huberts pics I guessed the position of the Starboard side stripe quite good
The horrid stains around the main wing crosses all but disappeared once the flatcoat dried completely thank goodness
The next hurdle was the kit parts for the access door, they were far too thick showing some sort of spring? or covering, glue points were misaligned,
spent too many hours trying to fit them so junked them and used the thinnest diameter brass rod I had to fit the door in place
Still needs a tidy up there.
Decided to add some ammo belts to the side feed kit MG's just to punish myself some more :gogo
