I have a wood base. Need some ground work on it. My past experience with Celuclay turned out not so good as it started turning up on end and didn't adhere to the surface that well, think it was suggested I need to add white glue to the mix, but I don't have any white glue.
The base I have has been stained and a couple of coats of polyurethane on it. I have on hand Vallejo Sandy paste, Liqutek Modeling stuff, the thick stuff, will get exact name if needed. And I got dry wall speckling.
What I want is a grassy field (for the Fokkin Eindecker.
What would you use?
)What would you use?
