Some famous last words before one of my projects end up on my shelf (more like a room) of doom. Yes, I like the sound of that...The travel locks were more a case of "can I actually do this and make it work" than anything else.
The ROOM of DOOM!
I have a scary sharp ancient Xacto chisel blade that I use a lot. It peels the little rivets off like butter. I have to work a bit to shave the larger ones off my molded piece, but it works better than anything else I could even think to use. I have to be "REALLY" careful with using it as it is almost dangerously sharp, but that is what makes it work so well.One RARELY reads that rivets are too small! Shaving them for later or simply grinding/filing/sanding away?
This is why I don't do anything larger than 48th scale. Too much detail to worry about. Well done! Gary S.
Completely plumbed and some will say that they're reference photos of the real deal too!By the time you finish this your scratch-built parts will weigh more than the original kit parts![]()
