M3 Lee
The edge of the causeway was too far forward, I cut about an inch out, moving the tank back towards the center.
I have overcome my bridge block...Does it look weak? Well it's supposed to! :smack:
I think one of my guys are going to be leaned up on a sign "Limit 2 tons".
I like it, but I have a few questions. The big one is why does the embankment not continue both right and left of the tank?
Back to the reference photo Doc, notice the approach behind the kids? Notice the embankment off both sides of the road. It's a causeway over the flood plain around that creek or little river. Man I wish there were more photos of this scene.
Keep in mind I'm not doing this exact scene but there sure were a lot of bridges crushed during these war games.
Oh yeah, there's going to be some support under there as well as a half assed guard rail up top.
I got a question for you guys who do these things all the time. Why is it a necessity for the subject be diagonal to the base? Reason I ask, I'm now thinking of filling in the creek bed with water and if I do that I'll have two corners where water will just stop. If I arrange this perpendicular to the base then it wouldn't be a problem.
The Rule of Thirds, the Golden Ratio and the Golden Triangle are the "rules" of composition that can give a diorama that dynamic feel and flow that guides the eye through the scene to find details and because they can be found in nature they make the scene "feel right". These will all place the focal point off centre and our brain gets excited when things aren't centred. Placing everything at right angles to the base makes it feel rigid, blocks eye and the viewer doesn't get the sense that the scene continues past the edge of the base. Make the base fit the scene not the scene fit the base.
RichB
All of the above are correct but in the end it still comes down to what you are happy with - its you who will be looking at the finished piece every day. What do YOU want to see?
I always make sure I work to this rule as the final check before locking into a layout for a scene/ dio.
:soldier
I thought I had the Tamiya German field kitchen set that includes at least one draft horse. I can't find it. I got two sets of mounted germans but I don't want a saddled horse.
I thought one of the farmers in this scene would have his plow horse along to take a look.
I've laid out what I think I like to see, I'm measuring 9x10 base, may grow larger if I find a horse.
