The issue i've always had with dremals is the shaft wobble. Since this is named an engraver is it prett steady? How's the torque?
I had read a review of a branded engraver someone raved about and copied the specs. This is what I used to search for the engraver and the resulting one I chose has these specifications. I will test it out soon.
"Electric Drilling Etching Pen Professional Cordless Engraving Drill
3 Gears Adjustable DIY Power Tools for Ceramic Metal Plastic
Feature:
1.Comfortable Grip: The well-designed engraving pen lets you use it like a pencil for a comfortable hand, better control and precise engraving.
2.Reliable Quality: High-strength metal and selected electronic parts are used, which are wear-resistant, wear-resistant and have a long service life.
3.Easy to use: The cordless engraving pen can work normally without a plug, eliminating the problem of wire confusion.
4.High Efficiency: This engraving pen can provide high speed of up to
5000-25000r/min, providing efficient engraving effect, three-speed adjustable, easier engraving. The electric engraving pen is powered by a lithium battery and can be recharged. No more disposable batteries!
5.Wide Range of Applications: It can be used to engrave metal, ceramics, wood, pebbles, plastics, etc. Perfect for DIY projects or craft use.
Specification:
Name: Mini electric grinding pen
Voltage: 3.6V
Battery capacity: 280 mA
No load speed: 5000-25000
Chuck size: About 2.35mm/0.09inch
Host length: About 12.4cm/4.88inch
Style:
A: 30pcs Grinding Needles
B: 42pcs in the set
C: 46pcs in the set
The full charge lasts about 90 minutes
After fully charged, the maximum speed, no-load, continuous operation about 110 minutes."
