Hey Paddy here is the video blog by Rick Lawler that you might find interesting....Enjoy
A point for those building . There are two fixed machine guns pointing forward that are a nightmare to fit if you do it in the instruction construction sequence so bear that in mind when fitting the front panel in front of the driver. wiki says these were removed in later production
anyway which may explain why the holes for them in the front panels are not opened up
I struggled with the running gear. I found i had to shorten the arms that the wheels hang on to get them to fit as a pair on their pivot points.
The model has quite a few pin and hole points to join halves together in a normal fashion however a lot of the holes are too small for the pin dia and a lot of the pins are little more than rounded lumps. With the suspension i found that the rounded lumps actually melted with the normal Revell glue so they no longer give a location. The upshot is i have assembled the wheels but i think they were supposed to hang freely and self align to the tracks however to do that their pivot points would have to have been the lumps that melted.so mine are fixed
A jig will help. @Iron Mike made one from just some wood and I think he ran a router bit down the length.OK so now i have 360 track links and 360 track sections that are to small to pick up with my fat fingers....
I am a complete novice at this so Is there a secret to this ? do i need to build a jig?
