Nice old destroyer kit. Where did you find that?
EJ
Happy Birthday Terry! Excellent choice!
A couple days ago we had our IPMS chapter meeting. I got this in the raffle:
Now since I also have the Renwal USS Springfield, I can build both of these.
Before that however, a friend sold this to me; using up the last of my Christmas money:
That is a white one-foot-long ruler on the top of that box. yes, it is that big. The fuselage seen below is made from fiberglass, as is the wings and tail surfaces. All other parts are injection plastic. The ruler is still there to show size:
Later I also decided to test-fit the wings to see how big this monstrosity is. The tail feathers didn't fit, but I was able to at least balance the vertical stabilizer:
Yeah, that puppy will have to be all done at Hobby Day....
That's it for now. I have four Brookhurst gift cards; prizes from my AMPS meetings so I may have some more to show after the Spruefest show. Stay tuned.
Cutting fiberglass, use carbide cutters, and diamond files for the edges. I suspect that the surface of the fuse is a resin coating so you can have the surface detail. HPH does this with their giant size kits. Give me a shout and I can visit with you about it a little. I used to make prototype PC boards by hand so have a bit of experience with fiberglass.
Something else that could help is pushing a plastic bag into the fuselage and then putting some expanding foam in. Dont over fill, just enough to add strength while you are cutting. That way the fuse wont flex on you. Then when done pull the bag out. Of course if its a really rigid kit you probably wont need that. Again just not too much foam so you dont distort the fuse. And a mentioned a good respirator. Fiberglass can be very nasty if it gets in your lungs or eyes etc.Thanks Paul. I appreciate that. When I get ready to start this, I'll let you know so we can chat. Yes, it has a resin coating on it; very smooth, but the seam still has a slight step in it that needs to be reduced.
TB, I will. I have just the thing that I use for my house painting, air-less paint sprayer. In addition to that, I have two fans: one in the window blowing outside; and the other behind me at an angle to blow the debris to the fan in the window.
Now to find some carbide cutters; I think I need a saw of some type too since there are a couple curves I need to cut. Or I can cut them straight and sand in the curves.....
