Military Bulldozer
Should have gotten some update shots but will do today.
Couple of impressions. This is not your beginner kit, if the part has an alignment pin it will not fit. Be prepared to drill out some holes.
The PE is really nice. It comes sealed in a clear plastic pouch, the inside is low tack tape so you can cut the PE without the fear of launching it.
I got the engine/chassis for the most part, both running gear/boogies built up. If part 70 is not at the mailbox today I'll start working on widening the dozer blade. I'm to the point of painting the subassemblies also. Otherwise
