Looking good![]()
Now how in the world did that break??
Thanks James!![]()
I have no idea how it brokeNeedle's bent too :S
Rough on those airbrushes ain't ya?
![Blink :blink :blink](https://modelersalliance.org/images/smilies/blink.png)
Looking good![]()
Thanks James!![]()
Looking good![]()
Thanks James!![]()
Rough on those airbrushes ain't ya?![]()
Your plane is shaping up very nicely .... there Ed .... But that AB is a bit crooked .... looks like it may have been hit with a Hammer .....
Thanks Fellas!This is ready ta paint. Just very little left to do on her... needta future the canopies, mask them & figger out howta prop her up when the time comes :hmmm
Dang AB ..... There's always a PB .........:geek :yipee
Things have changed up today so, I'm home & decided to pull the a/bs down but, since my back is hurting I'm not doing too much today.
Here's the Badger 175 that's broke![]()
I just found out the part is $$9.50 thru Badger (part#41-016) Needle tube.
I swapped out parts with my other 175 but have yetto give it a shot :idonno May do that later. along with tear down of my 200...
Anybody have any exp. with the Badger Hybrid 3155? Just curious....
Just a little.... :coolio
Nothing wrong with it, it's a suction feed A/B, more stuff to clean up and swapping colors is a bit more of a chore. You can get a good tight line with it. It's basically the same as a 155 but with a more fine needle. IIRC, problem I had was the pattern was too tight, doing large areas was a chore. Small scale stuff should be no problem.
you will, it was hard to use for covering really large surfaces, 1:32 wings and such.
